Bosch WBB24759 skipping spin
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WBB24759 skipping spin
  • #37674
    snig
    Hi, Got a customer with big bosch just out of guarantee. Intermittantly it will spin but 9 times out of 10 jumps to end off programme.No obvious fault, tested motor circuit, pressure system, and drain etc. Suspect motor module but quoted £220 +vat. Am reluctant to take this chance. Any ideas
    #256004
    smartin
    Re: Bosch WBB24759 skipping spin
    have you tested the machine ? if not 1st port of call would be to ask customer what sort of washing they are putting in as if could be something as simple as the oob detection is detecting uneven load and its timing out
    smartin
    #256005
    Big drum/small load just exacerbates OOB problems………..
    smartin
    haier being the exception to the rule on that 1 chris, small drum any load no difference 😆
    #256007
    snig
    Hi, Yes ,tested with full load and empty but no difference. Sometimes won’t even attempt to spin before jumping to end of prog.
