Hi, I have a WBB24759 washing machine which does not spin or tumble, when testing it after taking an obstruction out of the pump it filled and tumbled ok but when I put it to a spin it just empties, same when I put it on a wash (fills for about 30 secs then empties and shows ready with no drum movement).
Checked the cable to the motor as it looks like it has given problems in the past.
Any ideas?
No, motor still not turning, checked heater element shows ok with no leak to earth but never checked the pressure switch etc so will check that & post update.
I personally don’t think the pressure switch would have any effect on the motor not working. Gotta be to be the module or motor lead I’m thinking. Have you tried removing the motor lead from the module and checked the motor continuity from that point?
