Bosch WD banging sound on spin
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WD banging sound on spin
  • #101015
    Mattypompy99
    I have a Bosch WVD24520 that clearly has a significant fault that it would be great to get any opinions on from anyone
    So, I ws just doing a normal cotton wash then on a particular part of spin cycles, seems to be towards upper end of the cycles rpm, a very loud rhythmic banging occurs.
    There’s also friction between the inside of the door seal and the basket lip with the lip of the basket heating up. aqueaks a bit with manual turning.
    I’m no expert clearly but I did a lighter balanced load and looking at the circular pattern at the back of the basket through the door, the spun doesn’t seem symmetrical. I took the top panel off. The two suspension springs look OK. I cannot remove the main side panels as I don’t have the correct torx tool.
    From what I’ve read I’m thinking broken suspension strutt or spyder, but can’t see them.
    I can include pics if needed.
    #483024
    spider failed
    Bosch has it proced at £162 then you need other parts to fit it
    I have guessed at your machine as Enr is incomplete
    Mattypompy99
    Hi Dave,
    Thanks awfully for the reply.
    Enr is Bosch WVD24520GB/11.
    How confident are you with that diagnosis?
    Absolutely not impugning your expertise incidentally
    Cheers
    Matt
    #483026
    Mattypompy99
    https://www.ransomspares.co.uk/parts/washing-machines/bosch/drum/59416.htm
    I’m assuming this is the correct spare?
    Thank you
    #483027
    that spare looks correct
    Bosch list it here
    https://www.bosch-home.co.uk/supportdetail/product/WVD24520GB/06#/Tabs=section-spareparts/
    get them to confirm price first as it looks like a special order item and the price may not have been updated
    as for the problem
    there are 3 legs to the spider. Chances are 1 has snapped. If you put weight on the drum by pushing down you should see it moved.move each paddle to the bottom and try. The very fact its now out of true and rubs the boot is a good indication I am right but can never be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}
    Mattypompy99
    Mattypompy99
    Forget previous post. That’s for a different component lol
    #483030
    Mattypompy99
    What other bits are needed to fit it Dave?
    Do you recommend getting a quote for fitting from an engineer or having s bash myself? I’m a reasonable DIY mechanic.
    Cheers.
    Matt
    #483031
    a lot depends on your skill
    other parts i would consider are
    1 bearing seal. not avaiable from Bosch but its here
    https://shop.ukwhitegoods.co.uk/7811729-drum-bearing-seal
    2 grease to lubricate above. Last a lot longer with it
    https://shop.ukwhitegoods.co.uk/universal-bearing-seal-sealant-grease
    3 tub half seal. You may well get away without this just depends on condition
    https://shop.ukwhitegoods.co.uk/00069632-washing-machine-tub-seal
    Mattypompy99
    Thank you for the kind advice Dave
    #483033
    andyjawa
    You can get a really strange one with these things. The spider actually visually has not cracked an arm but where the shaft is embeded in the ally spider it flexes at that point on most loads causing rubbing of the rubber door seal, a somewhat dreadful noise and a concentic running drum at top whack spin speed.
