Bosch wet 2820 not spinning
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch wet 2820 not spinning
  • #41059
    nobby123
    Hi M8s
    we have a Bosch wet 2820gb/13 washing machine, last week just stopped and gave error code “prewash” light on “Anticrease” light on and “3” in the dryer display window, i checked and changed the motor brushes which were worn, tried it again now get “washing” light on “Anticrease” light on and “1” in the dryer window, have checked pump,water inlet hose etc . The machine washes and pumps water out but wont spin and gives error codes. Have turned programme selector to “Off” and proceeded again, wont spin and can get either of the above fault codes, it also fills very high with water ,
    any help will be appreciated nobby123
    #268665
    gegsy
    Re: Bosch wet 2820 not spinning
    Hi Nobby
    First fault you had was an overtime on the fill ie low water pressure, kinked hose/s etc.
    The fault now is saying that it has exceeded the pump out duration but still has water in the drum above a certain level.
    You may have a blockage in the pressure system or a faulty pressure switch.
    I personally would be looking for some sort of crud build up in the pressure chamber at the front bottom of the tank TBH 😉
    Power off if you are to investigate :plug:
    nobby123
    Thaks for that gegsy
    just found fault , container at rear of machine going to soil was blocked solid with crud and pipes going into soap dispenser also blocked,
    cheers M8s
