Bosch WET 2820GB/13 not draining
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WET 2820GB/13 not draining
  • #27900
    suedehead1
    i went to this bosch washer dryer it fills turns heats spins but doesnt empty. in fact the pump doesnt go at all.
    i tried a new pump but it doent go either.
    i took off the large computer board in the base of the machine there is no sign of dry joints or bad connections i checked the wiring from the board to the pump and its ok.
    i suspect the board but as i expect it will be a fairly expensive part i would like a second or third opinion.
    thanks in advance.
    #216020
    Re: Bosch WET 2820GB/13 not draining
    Sounds reasonable to me, Suede. P/no 295666, £160 odd trade though.
    suedehead1
    thanks for the quick reply it might be an option repairing it as its integrated and would probably have been an expensive machine when installed originally.
    i might speak to emw tommorrow to see if it can be repaired.
    thanks again.
    #216022
    EMW doesn’t do that one – QER list it, but it’ll be a send it off and wait job.
    suedehead1
    thanks for that i will give them a try.
