Re: bosch WET2820
dna wrote:hi have a bosch WET2820 not spinning. Timbles ok. WHen on spin setting its just tumbles the finsihes after about 15mins. I thought brushes but it only come as a motor half any help would be great.
I wouldn’t rush out and get brushes and/or motor end frame if I were you on this fault. 😉
Now, going back to what you said for a minute here, the motor tumbles OK, yes or no? You said it does 😉
Therefore, the brushes are OK!
Next step, is the pressure/air bell clear? Is the heater element OK? If both are YES! Then I suspect the main power module is the culprit? In fact from here right now I’m certain that’s your problem. Unless you can come up different?
HTH?
