Bosch WET2820GB/01 Changed motor end frame
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WET2820GB/01 Changed motor end frame
  • #76976
    Bernie
    Bosch WET2820GB/01 Changed motor end frame, (as brushes worn out) now on wash, motor turns 4/5 sec stops, turns again 4/5 sec stops, goes in the other direction for 4/5 sec stops and that is it no flashing leds, just sits there.(when it does run it seems a bit fast, not the normal was speed)
    On spin it will spin for 4/5 sec stops spin for 4/5 sec stops, spin again for 4/5 sec, and that is it.
    I did not mark the position of the fields to the end frame, but did check I had continuity through the fields and armature at the motor plug, so guessed I had it round the correct way.
    When it did not work I tried the fields round the other way, but still will not run for more than a minute.
    Did the old worn out brushes do something to the PCB?
    Many thanks for looking
    Bernie
    #400302
    Re: Bosch WET2820GB/01 Changed motor end frame
    Bernie wrote:Did the old worn out brushes do something to the PCB?
    What was the part no of the end frame, was it 00496876 ?
    #400303
    sounds like a tacho problem
    or wrong part
    have you got tacho continuity and output when motor turns
    Bernie
    Yes Martin the part number was 496876
    I was wondering about the tacho, where is it on these?
    Bernie
    #400305
    Bernie wrote:I was wondering about the tacho, where is it on these?
    Tacho built into the end frame.
    The tumbling for 4/5 seconds is therefore a bit of a worry and I’m thinking you may have to dig out the module on the base and check that out. 🙁
    #400306
    Bernie
    Found the tacho in the end frame, new one tests the same as old one. Other than continuity testing is there anything else I can do?
    Bernie
    #400307
    Not done one of these for years but is it possible to fit the field coils the wrong way round somehow? have a distant memory of such a thing.
    the pcb triac is available on its own for that one 00155272 so may be worth a punt.
    #400308
    alster
    I think the tacho has a plug on the end frame that plugs into the main part of the motor,has the plug missed the socket so to speak?? Alan
    #400309
    Bernie
    Thank you for all your suggestions, but it was a faulty part.
    I fitted new brushes to the old motor end frame(yes it can be done)and it all worked as normal.
    Thanks again
    Bernie
