Bosch WET2820GB/13 Motor open circuit
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WET2820GB/13 Motor open circuit
  • #27726
    bobokines
    Hi. Is there a Bosch expert that can help me please.
    I have a WET2820GB/13 with no motor action. The motor has continuity through the armature and the field windings. However pins 1,2 and 3 on the connector block are open circuit.
    I cannot appear to get any tacho continuity
    Questions:
    How is the motor wired internally?
    What does one get in an end cap? BSH096805 (tacho or just brush ring)
    Is there an over-temp cut out built into the end cap that can be replaced?
    Or do I need a new motor? bsh140867 😥
    Thanks in anticipation of a sensible priced outcome for this customer
    Bbo
    #215355
    Re: Bosch WET2820GB/13 Motor open circuit
    bobokines wrote:What does one get in an end cap? BSH096805 (tacho or just brush ring)
    The new End Frame/Brush Ring is now 496876 and literally has just the new type 154740 carbons. The old one however did have a built-in TOC and that could be your problem as likely as not it’s open circuit?
    The 3 wires to the tacho sensor are open circuit by the way! 😉
    #215356
    bobokines
    Hello Martin.
    How does the tacho work if it is open circuit? I assumed it is a coil as in any other motor.
    I do get continuity from the terminals to the armature. And from the field terminals and centre tapping. How is the TOC wired?
    Bob
    #215357
    gegsy
    Pins 6-7 on motor should have some resistence IIRC 23 Ohms pin 8 is the ref off tacho AFAIR 🙂
    Check email Bob
    #215358
    Bryan
    Hi Bob
    The TOC is in series with the armature but I asked the same question about the tacho a couple of years back and no-one gave me the answer.
    http://www.ukwhitegoods.co.uk/modules.p … =096805{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}2A
    My guess would be the brushes are on their very last piece of carbon dust giving you continuity with your meter but only splitting the motor will reveal all. When you get the end-cap off all will be revealed.
    HTH
    Bryan
    #215359
    bobokines
    Greg, thanks for the email.
    Looking at the wiring diagram, I am begining to wonder if it’s the control to the motor at fault.
    I can see the brushes through the end cap and it would appear that there is plenty of life left in them. The appliance is low usage and only 2 and a half years old.
    Be interested to know how the tacho works without a coil…
    Bob
