I have a bosch wet2820gb/13 washer/dryer and it has turned itself off. I changed the fuse and it came back on briefly before turning off again. i checked the fuse i removed and it worked.
Any ideas as to the problem?
Cheers
Have you checked the mains plug for signs of overheating ie disfigurement of plastic around pins of plug?
Have you tried the appliance in a different mains socket?
Have a go at those and come back to us 🙂
the trouble is its hard wired into the wall and so i can’t try it in another socket or try something else in the same socket. Perhaps i’ll just have to call someone out to have a look at it. Cheers
