The above Bosch washer/dryer has an intermittent fault where it stops during the cycle.
It stops during the wash and rinse.
The lights stay on as they were at the point of the cycle.
It stops with water in it also when empty.
If you switch the power off then back on it will continue through the cycle but could stop again.
There is no earth fault.
Have had the pressure switch cause odd sticking on these machines, usually at high level just as it switches the water off.Not a cheap part for what is an old machine now. Also seen the main PCB cause this.
I had considered the pressure switch but disregarded it as the machine continued after turning off then back on, would you agree with this or do you think it still a possibility?
If not it looks like the PCB.
I would be more inclined to the pressure switch if you can turn the machine off then back on. However I am not App Care, but have you tried going into diagnostic to see the last recorded fault?
