Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch WF 02865GB Filter Leaking
- This topic has 6 replies, 3 voices, and was last updated 16 years ago by
PJ50040.
March 16, 2010 at 11:27 am #53270
PJ50040
ParticipantBosch Exxcel 1400 Express (washing m/c)
WF 02865GB/01 FD 8302 701877Recently noticed laundry floor was wet. Wasn’t sure whether culprit was washing machine or roof. (Turned out to be both!!)
Water is leaking from front of filter housing on front of machine. Filter has been removed and cleaned (there was almost no debris in it) and re-fitted, but it doesn’t seem to be tightening properly. Thread appears to be ‘jumping’ once nearly tight. There is no obvious damage, and the seal is present and clean. Mating face of seal was wiped, but not inspected closely due to very large puddle on floor!
Tried re-fitting filter and running a (30deg wool) wash: noticed large leak (first) then after further tightening, leak reduced to a trickle. Cycle finished OK.
Is there anything else I should look for or try?
If obtaining spares, is the filter rubber washer or complete ‘cap’ available separately, or will I need a complete assembly? (If the latter, is it available separately to the pump?)Incidentally, is the pump on this type always so noisy? I had to replace it a year or so ago and the replacement (obtained via this forum) was as noisy as the original one.
PJ
March 19, 2010 at 6:43 pm #315177PJ50040
ParticipantRe: Bosch WF 02865GB Filter Leaking
Any suggestions for a temporary fix?
PTFE tape? Silicon sealant?
March 19, 2010 at 7:28 pm #315178Penguin45
151409 – filter and seal – Askoll pump
182430 – filetr and seal – Copreci pumpPenguin45.
March 21, 2010 at 8:33 am #315179PJ50040
Thank you for the information. 🙂Is there any way of telling which of the two parts I need without removing the pump from the machine?
(I fitted the pump, so I know what’s involved and don’t want to make extra work for myself if I don’t have to.)PJ
March 23, 2010 at 9:31 am #315180IWANTBLUE
PJ50040 wrote:Hi
Power off!
if you take off the kick plate and look through the hole with a torch you should be able to see the lable on the pump motor.
hth.
mine was askoll on the same machine, and I could clearly see the askoll lable on the motor from there 🙂March 24, 2010 at 1:55 am #315181PJ50040
Thanks for the idea; it did the trick. I discovered there was no obvious manufacturer’s name, but the following was written on the label:
Drain Pump
R20-6
30W 0.2A
20l/minI managed to take some photos of the pump and the filter (see http://pbckt.com/sg.vON)
However, I also remembered that I ordered the pump from this site, and found the order details from September 2008…
The pump is a “BS51120 – Bosch & Siemens Washing Machine & Washer Dryer Pump” but I am certain it did not come with a filter/housing.March 29, 2010 at 9:32 am #315182PJ50040
ParticipantRe: Bosch WFO2865GB Filter Leaking
I hate finding unfinished forum threads…
Armed with the above information, I asked for help at the spares section of this site. There were three possible filters (each about £10) depending on pump manufacturer, but I was advised that “the BS51120 is a ‘pattern pump’ so none of the listed filters will fit” and I would need to order a complete pump to get a replacement filter.
After the prompt email response in the spares section, the order processing was equally fast, and, having paid the extra for courier delivery, the part arrived the next day. Can’t complain about this for service!
It seemed silly having a new pump and just swapping the filter over, especially when there was a chance that the housing thread was damaged rather than the filter. Twenty minutes later, the washing machine has a new pump fitted and no leak!
Thanks UKWhitegoods (and hopefully this pump will last longer than the previous one!)
PJ
PS — Readers may be interested in this UK Whitegoods page about washing m/c drain pumps:
http://www.ukwhitegoods.co.uk/help/fix- … pumps.html—
PPS – Note that the washing machine model is: WFO2865GB (WF ‘Oh’ not WF ‘zero’)
