Re: Bosch wf 2000 does not pump out
With the machine turned off………
Remove filter. Put finger on centre boss of impellor and wiggle from side to side. Any discernable movement means that the magnetic armature has worn the plastic pump housing and the pump must be replaced. There is no start capacitor required for a magnetic motor.
Full Enr number required to identify correct pump (check inside of door).
This is also worth a read:
http://www.ukwhitegoods.co.uk/modules.p … ge&pid=160
