Bosch WF02864
  • #15038
    jemtee
    Replaced brushes on machine and worked great for about 20 washes. Now when it reaches spin cycle – 11minutes on display – it works till 9 mins then jumps to 1 minutes and ends. It has not spun out. Any ideas please
    Janet
    #161768
    superfix
    Re: Bosch WF02864
    Does it pump out the water?.
    Are there any lights flashing on the fascia?.
    #161769
    jemtee
    Re: Bosch WF02864
    It pumps out the water and there are no lights flashing on the fascia
    Janet
    #161770
    Re: Bosch WF02864
    One of the brushes most likely has overheated and is sticking in its housing 😉
    #161771
    jemtee
    Re: Bosch WF02864
    took out the brushes last night to check in case they were sticking, replaced them and still the same result with the spinning
    Janet
    #161772
    Re: Bosch WF02864
    Is the motor turning at all?
    #161773
    jemtee
    Re: Bosch WF02864
    The machine runs fine with the drum turning etc right up to this point.
    Janet
    #161774
    Goatboy
    Re: Bosch WF02864
    Did you buy genuine Bosch brushes? 😕
    #161775
    jemtee
    Re: Bosch WF02864
    I bought the brushes from UK white goods but they are probably not genuine spares
    Janet
    #161776
    Goatboy
    Re: Bosch WF02864
    :eeek:
    When an qualified engineer changes the brushes, he/she will do a few things to make sure those brushes last; like, cleaning the armature, and cleaning the carbon disposits off the PCB, especially the little heat-sink, as this could cause a short circuit on the PCB, and lead to a dodgy motor as you describe 🙁
    #161777
    jemtee
    Re: Bosch WF02864
    Hi seems to be ok now thanks a lot
