Bosch WF02864 Motor
  • #34295
    Keith52
    Can anyone tell me how to disconnect the wiring from the motor on a Bosch w/m model WF02864 (Exxcell1400).
    Have managed to undo bolts but cannot see how to remove wiring so I can remove motor to check the brushes.
    Machine will not wash/turn/motor sound so guessing brushes may require changing. Worked fine one minute then all stop.
    Any help is much appreciated. 💡 💡 💡
    #242082
    bazza500
    Re: Bosch WF02864 Motor
    It just a push-in plug. May have two little hooks on it which need lifting but even with these moved they can still need a good pull to get it off.
    #242083
    Keith52
    😀 Thanks, had to lever it off as no room to get at it but it`s off now to see if brushes is the problem.
    #242084
    Keith52
    Back again, Have removed brushes to motor and apart from looking to be about a 1/3 of the size shown on web photos they look in good condition, no pitting broken bits etc., not sure now if this was the cause of the fault, any ideas anyone?
    #242085
    gegsy
    Clean motor com with comstick, re assemble and try again 😀
    Keith52
    gegsy wrote:Clean motor com with comstick, re assemble and try again 😀
    Would you recommend fitting new brushes 1st or refit old ones?
    #242087
    gegsy
    I would, personally 😉
