Bosch WF02864GB/01 wash cycle stuck 0:01 minutes remaining
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WF02864GB/01 wash cycle stuck 0:01 minutes remaining
  • #83279
    tonyb61
    This machine appears to run through a wash cycle but ehen it gets to 0:01 minutes remaining, it stays there, turning the washing endlessly.
    Tests
    I have taken the drain hose out and when you drain the water comes out freely.
    Checked filter is clean and pump appears to turn ok
    Drain, spin rinse programs all work correctly.
    Cold wash program runs through and ends correctly.
    Any hot water programs seem to get stuck when they reach 0:01, although they seem to go through the fill/wash/rinse/spin cycles ok.
    Any ideas ?
    #422328
    Re: Bosch WF02864GB/01 wash cycle stuck 0:01 minutes remaini
    Might help…
    http://www.ukwhitegoods.co.uk/help/fix- … inute.html
    tonyb61
    I did look at this. I discounted the motor earth leakage as a cause since many programs do run through ok, including a cold wash. The heater is suspect so I ran through a 90C hot wash this morning, and it seems to be not actually heating up at all. So I might measure that this evening. What are the typical resistance figures for a element ? I’m guessing something like 30-50 ohms ?
    #422330
    lee8
    Ohms law. The voltage and wattage will give you resistance, both should be written on the element plate. Its a common symptom when element goes.
    #422331
    tonyb61
    I worked out 28ohms. I’ll check tonight when I get home.
    #422332
    lee8
    Sounds about right
    #422333
    Heater relay on main circuit board gone AWOL. 🙁
    #422334
    tonyb61
    I hope not as I took a chance and ordered a replacement heater ! 🙁
    At least a relay should be easy to replace if it is that, and not too expensive.
    #422335
    lee8
    Heater relay on Pcb? On a washer. Simple resistance or voltage check first.
    #422336
    tonyb61
    I’m an electronics engineer with access to pcb rework equipment and purchasing of components if needed. But I’ll test it first. I still think the element is more likely as a test should confirm…
    Fingers crossed !
    #422337
    Dansta
    Rather than over complicate things id check the connections to the element, I’ve found them burnt out on several occasions, if there ok, the element should read around 30ohms, worst case will be the pcb. Unplug before testing!
