Bosch WFB 2000 – Draining and spin trouble
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WFB 2000 – Draining and spin trouble
  • #8985
    My Bosch WFB 2000 is playing up. Sometimes it fails to drain properly (though this can be overcome by sending it round on another program) and other times it won’t spin properly and all the clothes are soaking wet.
    Am I right in thinking that probably both the pump, and the brushes on the drive motor could do with replacing?
    I think the right pump is the PMP230, is that correct?
    I’ve also no idea which brushes to get. Can you help?
    Many thanks,
    Jamie.
    #131486
    Re: Bosch WFB 2000 – Draining and spin trouble
    Jamie,
    Have you actually taken the filter cover off and checked the pump is blocked? Is the impellor rotating? Full model number would be appreciated to establish the correct pump number but it is NOT PMP230!
    BSH-MAN
    If it fails to drain then it will not spin. Are you sure you have two separate faults?
    Have you had a good look at the pump impellor by removing the filter and checking for debris.
    #131488
    BSH-MAN wrote:Have you had a good look at the pump impellor by removing the filter and checking for debris.
    What is this….an echo? :rotfl:
    #131489
    clivejameson
    ….and if you’re in a hard water area then it will most likely be scum blocking the internal and external tubing…that won’t need any parts at all but a bit of hard graft and a strong stomach! (you might get as much as two pints of the stuff out ;))
    #131490
    Martin and BHS-MAN,
    Thanks for the prompt reply. Very glad that I checked first. I had checked the filter and impellor but had another go and discovered a white paper clip was blocking the impellor about half way through a turn, which is why I missed it the first time.
    Thanks so much for your help.
    Jamie.
    #131491
    I like Fishpaste – on my toast in the morning 😆 😆
    But seriously, well done.
