Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › BOSCH WFB 2004 BEARING REPLACEMENT
- This topic has 6 replies, 4 voices, and was last updated 20 years, 10 months ago by
happytadpole.
May 24, 2005 at 2:15 pm #9762
happytadpole
ParticipantThe drum on my Bosch WFB 2004 washing machine seem t ohave a rumbling bearing. Is replacing it a straightforward job for a mechanically competent person (which I am) or do I need special tools etc? Is it a single item or replaced in a set with other components? And the next obvious question is: where can I source a replacement?!
May 24, 2005 at 2:30 pm #135721Martin
ParticipantRe: BOSCH WFB 2004 BEARING REPLACEMENT
Oh you are going to love changing the bearings on this baby! Not an easy task but rather shall we say a challenge for you. Now Bosch do not supply the bearing kit for these (just the complete Drum Spigot/Bearing Unit at around £110). But we can source a set of Bearings and seals to fit if you wish (Simply email your request to spares@ukwhitegoods.co.uk. )
Good luck, and if you get stuck you can always ask one of us to fix it for you at a modest cost via our : Repairs@
May 24, 2005 at 3:07 pm #135722BSH-MAN
happytadpole wrote:The drum on my Bosch WFB 2004 washing machine seem t ohave a rumbling bearing. Is replacing it a straightforward job for a mechanically competent person (which I am) or do I need special tools etc? Is it a single item or replaced in a set with other components? And the next obvious question is: where can I source a replacement?!
What’s the four digit number after FD on the lable? (on the door frame)
May 24, 2005 at 3:18 pm #135723happytadpole
FD 7805
Fun job, is it?!
Thanks for the fast answer. How much is that bearing, then?
May 24, 2005 at 3:25 pm #135724Martin
happytadpole wrote:How much is that bearing, then?
“That bearing” is 2 bearings and a water seal kit at around £25 ‘ish, we could get one set for you?
May 24, 2005 at 7:27 pm #135725superfix
Oh dear 😉
What a lovely jobMay 24, 2005 at 9:56 pm #135726BSH-MAN
It’s a seven year old, bottom of the range washer. If you can get bearings for £25 and have the inclination then it may be a viable repair.
But I would think long and hard about spending a lot of money on this appliance at this age. :duck:
If you do go ahead then I’m sure you will get good advice from the guys on this forum.
:tup: -
