Bosch WFB1605 speed control
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WFB1605 speed control
  • #20402
    philpearson
    I have a Bosch WFB1605 with ineffective speed control. The drum runs at full speed in alternate directions during the wash part of the cycle.
    I haven’t yet investigated the problem further.
    What should I be looking for to fix the problem?
    #186962
    gegsy
    Re: Bosch WFB1605 speed control
    Its either the tacho on the motor or the speed control module itself at fault.
    May I suggest an engineer from the link below.
    gegsy
    Just to add, you could have earth leakage from a component aswell causing fault.
    philpearson
    Thanks.
    I’ll try to check the tacho output when I get chance to get the thing apart; what voltage should I expect at full speed?
    How feasible is it to replace the speed module or tacho?
    #186965
    gegsy
    We don’t recommend “Live” testing of any appliance. Please unplug appliance and cold test components with a multimeter.If you have any doubts please use the link below for an engineer.
    philpearson
    I checked the tacho and I think it’s probably OK; I can get about 3V a.c. when spinning the drum by hand.
    Assuming the fault is with the speed control module where can I get one? It’s a COPRECI BYR891-3
    Thanks in advance.
    #186967
    gegsy
    Hi phil
    If you can supply the full model number (around door or on the rear), we will be able to go firther for you.
