Bosch WFB1605GB/12
  • #8956
    Looked on the BSH Quickfinder site for either drum bearing kit or bearing seal but I can only find the bearing cross, part number 283725. Bearings are 6204 & 6205, seal is 30-52/62. If I can only buy the complete bearing housing the machine is not worth repairing so does anyone offer a bearing kit or seal for these machines?
    Cheers, Phil
    #131333
    Dave_Conway
    Re: Bosch WFB1605GB/12
    Nope, I had the same problem last year with one, the seal was a different size though.
    The closest I can come up with is from Maddocks which is 30 X 52/65 X 10/15
    The “65” being the outer lip which seals the spider to the drum, it should fit I reckon as it’s only 3mm larger in diameter.
    Their part number is 54-ZN-16 priced at the almighty 59p, gotta be worth a shot 😉
    They’re on 01443 842371
    #131334
    Many thanks, I will give them a ring. Sounds a bit better than £93.26 for the bearing cross. 🙂
    #131335
    ….also Masterpart do a Bearing (& seal) Kit to fit this model at £11.99 (their stock code BS05110)
    and it fits the following models too..:-
    WFB1602GB/16, WFB1602GB/22, WFB1602GB/26, WFB1602GB/27, WFB1602GB/30, WFB1602GB/33, WFB1602GB/36, WFB1605GB/11, WFB1605GB/12, WFB1605GB/15, WFB1605GB/16, WFB1605GB/22, WFB1605GB/26, WFB1605GB/27, WFB1605GB/30, WFB1605GB/36, WFB2000GB/03, WFB2000GB/07, WFB2000GB/12, WFB2004GB/15, WFB2004GB/31, WFB2004GB/33, WFB2004GB/36, WFB2005GB/31, WFB2005GB/33, WFB2005GB/36, WFB4000GB/01, WFB4000GB/02, WFB4000GB/07, WFB4001GB/01, WFB4001GB/02, WFB4002GB/01, WFB4002GB/02, WFD2060GB/01, WFD2061GB/01, WFD2070GB/01
    Dave_Conway
    Have you worn your b key out yet Martin ? 😆
    #131337
    Dave_Conway wrote:Have you worn your b key out yet Martin ? 😆
    bbbbbbbbb….nope, not yet, thank goodness eh? :rotfl:
    How do you make a bearing cross? Smack it a few times with a dirty great lump hammer :clown:
    #131339
    Martin114
    Martin wrote:….also Masterpart do a Bearing (& seal) Kit to fit this model at £11.99 (their stock code BS05110)
    Just had a call in for bearings on a WFB4001GB/01. Not done one before – does the bearing spider remove through the back panel or does the tub have to be taken out?
    Cheers
    martin
