bosch WFB2000 spin problems
  • #34538
    simon26r
    WFB2000
    machine wil spin every time on a (cotton wash) long spin but if you do a (H wash) short spin it can take upto 10 goes to get it to work
    does anyone have any clues?
    the pump has just been changed as customer 1st said it was not draining but on 2nd visit changed story to maching not spinning..
    thanks
    simon
    #243067
    Re: bosch WFB2000 spin problems
    simon26r wrote:but if you do a (H wash) short spin it can take upto 10 goes to get it to work
    Check the brushes, the tacho connections on motor plug, wiring loom connected to motor bracket, air pressure chamber and finally the module?
    Often these machines motors run ‘jerky’ and the tacho connection between module and motor need a close look? 😉
    #243068
    Intermittant spin is often the Eaton timer.
    gegsy
    Penguin45 wrote:Intermittant spin is often the Eaton timer.
    Wasnt that a Jam single :duck: 😀
