Bosch WFB2004GB/33
  • #20392
    andy2
    Hi – I need to fit a new on/off switch pushbutton to this machine which means releasing the front white panel from the black panel behind it. Have tried for a while with no sucess and don’t want to break anything so can anyone point me in the right direction please.
    Andy 😀
    #186928
    Re: Bosch WFB2004GB/33
    Remove dispenser drawer and remove screw holding fascia in place there. Remove the 2 screws holding the front panel in position and lower the front panel slightly clear of the fascia panel. Then with a knife blade placed between the right hand side of the fascia, press a screwdriver into the latch recessed slot on that side at the same time twisting the knife blade to ease the panel forward and clear of that latch. Use the same knifeblade technique on the left hand side to ease the panel forward. Then hold the panel and pull it clear and away.
    Putting it back is easy as long as you align the temp and timer knobs before simply pushing it into place!
    #186929
    andy2
    Thanks Martin very much appreciated. It is not obvious on these how they come off and with the cost of a new one being £77 i did not want to risk breaking it. 😥
