Bosch WFB2005GB/33 Leaking dispenser.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WFB2005GB/33 Leaking dispenser.
  • #44309
    Twoten
    The above machine leaks when filling.
    The water pressure is very high which causes the water to flood out the front of the dispenser.
    The valves both have the original restrictors so I have turned the pressure down at the tap.
    Is it possible to get alternative restrictors that will cope with a high volume of water for this machine in case the tap gets turned on full again in the future?
    #280608
    neilsukwg
    Re: Bosch WFB2005GB/33 Leaking dispenser.
    A 15mm check valve, the type that have a slot for a scredriver rather than a handle, placed directly before the tap valves will sort it.
    Involves a bit of plumbing, but the only way to ensure the pressure is not altered by customer, or when machine out for decorating, etc, etc.
    #280609
    Twoten
    Thanks for the reply neilsukwg,
    I know the type, a ballafix valve.
    I was hoping for a restrictor to fit inside the inlet valve connection rather than altering the plumbing.
