BOSCH WFB2405GB/33 W/M NO SPIN
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries BOSCH WFB2405GB/33 W/M NO SPIN
  • #31201
    Any ideas as little unsure…..went to this this morning
    customer says it doesnt spin….did all usual things (level switch,
    drain etc)
    and tested by manually turning timer to spin and it
    works fine….but if I put it on earlier in the program
    and let it work round to spin it doesnt do it????
    Timer feels very tight to turn….
    I feel its the timer but anyone got any other ideas?
    regards col
    #230234
    clivejameson
    Re: BOSCH WFB2405GB/33 W/M NO SPIN
    Have you checked the motor brushes? I’ve had two or three where it appears to work fine until either the motor has warmed up or there is a large load in there 😉
    #230235
    No didnt check them as drum contained very heavy load…..
    Also stayed with appliance for about an hour with it running
    and seems to function fine every time I selected spin…..
    timer does turn to end stop as well just doesnt spin when
    a wash program is running. Another repairer fitted new brushes
    6 months ago….
    Regards Col
    #230236
    clivejameson
    Pressure system? :con:
    Failing that, time for one of the Bosch boys to chip in?
    #230237
    Pressure system fine…..
    I was wondering if there was something obscure
    like out of balance sensor? but manual doesnt mention
    one……
    Any Bosch guys got an idea what this could be?
    Regards Col
