Bosch WFD2060GB/01
  • #21940
    This machine has been in storage for 12 months, customer ran it on a wash without clothes to flush it through. He thought he noticed a ‘warm smell’ but not sure, he then set it for a normal wash and there is no sign of life.
    As a quick check I replaced the door interlock, even removed the slightly broken door handle to make sure it wasn’t fouling without success, no lights , door won’t lock, not a peep.
    I can trace a circuit from the mains suppressor to the door lock but no neutral, I can also trace a neutral to the selector switch on the module. I can neither see or smell any sign of component burning or damage.
    Could this be a module fault, just had a look at the price, lets just say its prohibitive. 😥
    gegsy
    Re: Bosch WFD2060GB/01
    Hi Jim
    You have more or less limited it down to module to be honest.
    It has had a part change to 493685 £157.59+ VAT list.
    As I said, prohibitive, or down right bloody ridiculous, such a shame on a still decent machine. A possible ISE candidate methinks. 😉
    Whirlpools new domino machine has had a problem with some of their ctrl boards, bad packaging meant moisture got into them, if its been in storage for 12 months, maybe there has been some moisture on the board?
    #193080
    Unfortunately the board is snuff dry, 😥 I would expect to see some lights on if it was just moisture on the board.
    Jim
    #193081
    Bryan
    Assuming it`s 481540 , Masterpart have stock at £84:99+vat.
    Might even be worth a call to QER ❓ but they normally ask for the number on the PCB to identify it.
    Bryan
    #193082
    gegsy
    Bryan wrote:Assuming it`s 481540
    Yes it was Bryan, that was the original but there must have been a component/software change for BSH to have supeceded it 😕
    Did you notice if the double pole rotary switch was making contact OK?
    #193084
    Martin wrote:Did you notice if the double pole rotary switch was making contact OK?
    I could see the contacts opening and closing as I turned it.
