Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch wfd2060gb/01 bearing cross
- This topic has 8 replies, 2 voices, and was last updated 13 years, 11 months ago by
bmrenr.
May 13, 2012 at 2:17 pm #69449
bmrenr
ParticipantHi I have the above m/c that needs a bearing change but it has a bearing cross and is very expensive.Has anyone taken this out and replaced the bearings and seal and if so does qualtex do a bearing kit for this.
Tom.May 13, 2012 at 5:12 pm #374840Martin
ParticipantBosch wfd2060gb/01 bearing cross
Masterpart do a bearing and seal kit, don’t think Qualtex do. I will check tomorrow when in office for the part no if you like?
May 13, 2012 at 5:17 pm #374841bmrenr
ParticipantRe: Bosch wfd2060gb/01 bearing cross
Cheers Martin I would appreciate that.
Tom
May 13, 2012 at 5:58 pm #374842Martin
Just checked my laptopamabob and have it listed as BS05109 and also available here on the UKW shop site (see link below)
http://shop.ukwhitegoods.co.uk/Washing+ … rings.html
HTH?
May 14, 2012 at 9:04 am #374843bmrenr
Cheers Martin would you have the sizes of the bearings and seal and I might be able to make it up out of some kits in my shed as the customer is in a hurry.
Tom
May 14, 2012 at 9:34 am #374844Martin
bmrenr wrote:as the customer is in a hurry.
Do what? Next day delivery too late for your customer eh, blimey?
Don’t have bearing sizes, but pretty standard, seal is a bit special so you’ll have a problem there my friend. Try your best to appease your customer, patient is such a virtue and getting the right parts such a necessity don’t you think? 😉
May 14, 2012 at 10:10 am #374845bmrenr
I’m in Ireland Martin unless masterpart have a base here I think it will take well over a week.
Tom
May 14, 2012 at 10:32 am #374846Martin
bmrenr wrote:I’m in Ireland Martin unless masterpart have a base here I think it will take well over a week.
Then order it direct from UKW and Dave will paddle over in his rowboat a lot quicker. 😛
Edit: I’ve managed to get the spec of the bearing kit as I have one here on my van.
Bearings = 6206zz& 6306zz
Water seal = 35×72/84×11/18May 14, 2012 at 2:16 pm #374847bmrenr
Cheers Martin thanks for ur help its greatly appreciated
Tom
