Bosch wfd2471 leaking
  • #92297
    AASWALES
    Hi this machine is leaking through a hole in the tub next to the sump connection, the hole is manufactured into the tub and looks like it could take a small hole or it might have had a bung? Does anyone have any experience of this hole? No bung on the floor? Thanks Alan
    #450857
    Re: Bosch wfd2471 leaking
    The Heater retainer spring fixing (00168794) come off?
    #450858
    AASWALES
    Sounds like it could be, do you have any digrams for this machine can’t seem to find any? Thankyou for your help
    #450859
    diags here
    http://www.bosch-home.co.uk/customer-se … pare-parts
    the spring fit in a grove inside and has no hole through the tub
    …..could be a victim to one of those new £1 coins of course. 😕
    #450861
    AASWALES
    No its hard to explain I wish I had taken a pic. My initial thoughts were a small pipe pushes onto it for draining but there isn’t a pipe for draining so I’m stumped as to why it’s there, it’s no so much a hole as a 20mm length 5mm hose coming out of the drum made of drum plastic, hope that makes sense it’s hard to explain, I’m thinking of just sealing it up??
    #450862
    AASWALES
    I haven’t got the enr as it’s worn off so can’t get the diag from bosch website
    #450863
    AASWALES wrote:I haven’t got the enr as it’s worn off so can’t get the diag from bosch website
    What even on the back panel?
    Anyway there are only 3 and they are pretty much identical….
    WFD2471GB/01
    WFD2471GB/08
    WFD2471GB/10
    It has to be coin damage. Are there dents in the drum I wonder?
    #450864
    AASWALES
    I’m going back tomorrow to have a better look will post some pics hopefully clear this up thanks for your help
    #450865
    AASWALES
    I finally managed to get back to this job today and here is a picture where the water is coming out?
    #450866
    A silicone bung or better still Steel Putty would sort it. Though I have no clue what that hole is about. And as mentioned earlier, nothing shows up on the parts drawing. 🙁
    #450867
    AASWALES
    Yeah I have sealed it up now, just strange that there is no evidence of a bung or anything, thanks for your help
