Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch WFE2021 prog fault
- This topic has 5 replies, 4 voices, and was last updated 18 years, 1 month ago by
bubs.
February 13, 2008 at 10:33 pm #34595
bubs
ParticipantRepaired a Bosch integrated WM WFE2021 a month ago. One of the top springs had broken, tub shorted against pump wires. It has been working fine since, new spring, wire fixed.
Now i cannot program the machine. If you put the dial on X and press start, the 3 neons cycle to show reset. But if you try to do a wash it starts on a rinse. The motor and pump are working. I tried to get it onto a spin, it drained then counted from 14 to 1 min and stuck on 1, no spin The short wash and high water lights keep coming on all the time.
Any ideas before i quote for a pcb?Thanks, not had one of these with prog problems.
GraemeFebruary 14, 2008 at 8:27 am #243261Martin
ParticipantRe: Bosch WFE2021 prog fault
bubs wrote:Any ideas before i quote for a pcb?
No real clues for you but quoting for a new PCB will surely make it a write off? The PCB’s tend to get blown tracks (that can be solder link repaired OK) due to motor troubles. I would suspect motor probs and a close look at the tracks on the PCB 😉
February 14, 2008 at 3:40 pm #243262smart
NOT TOO SURE. BUT HAVE HAD ONE GO TO 1 MIN BEFORE DURING A DRY CYCLE. THINK THIS IS TO TELL YOU ITS DETECTED A FAULT. IN THE CASE I HAD IT WAS AN NTC FAULTY. BUT AGREE WITH MARTIN SOUNDS LIKE A MOTOR FAULT
February 14, 2008 at 7:11 pm #243263lerch
Alot of the bosch appliances do a quick self test when they first switch on and I have had quite a few where the ntc can cause this fault as well as the motor. Worth checking both if this is one that uses self test. Also as Martin says check the pcb as most of the time you can repair. 😯
February 14, 2008 at 11:09 pm #243264bubs
Thanks everyone, having a look Sat.
Will post any updates.
GraemeFebruary 17, 2008 at 1:29 pm #243265bubs
The customer has purchased a new machine. Thanks for your help.
Unknown to me it had gone wrong 4 times in the last 2 years, twice for motor brushes. So pos a motor fault, i had it washing but not spinning.Graeme
