Bosch WFF 2000 GB Temperature problems
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WFF 2000 GB Temperature problems
  • #13440
    arobinb
    The dreaded flashing pre wash light again. Followed the instructions to test the element and to clean the inlet, pump and level bell. Worked a treat, Now no flashing light. HOWEVER:….
    after every wash the laundry comes out hot. Either the thermostat,(or equivelant) is not working or the heater is not swithching off.
    I have checked the thin brown wires to the conector next to the element, and all the way back to the main board, and have looked for any other wires I may have dislodged inadvertantly.
    ❓ QUESTIONS
    1. Any suggestions as to what has gone wrong.
    2. How can I test whether the thermostat function is working properly. I have simple test gear, ie. a good multimeter.
    3. If necessary can I get replacement components and are they easily installable?
    This is urgent as the machine services an active family of 5
    #154868
    gegsy
    Re: Bosch WFF 2000 GB Temperature problems
    When you sorted previous fault out did you have to disconnect appliance from water supply?? If so I would imagine you have the hot and cold hoses the wrong way round.
    Greg 😉
    #154869
    Washman
    Did you disconnect the inlet hoses at he back of machine , you may have reconnected them back the wrong way round if machine is finishing with everything hot . Becuase the rinces should be with cold water so should be cold when you take things out.
    Mike
    #154870
    arobinb
    Thanks both of you I will try that. If you hear nothing it’s fixed. Thanks
