Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch WFF 2000 Intermittently Not Draining
- This topic has 14 replies, 4 voices, and was last updated 17 years, 3 months ago by
Shaunf.
January 11, 2009 at 2:25 pm #42484
Shaunf
ParticipantMy Bosch WFF 2000 intermittently ends up with the prewash indicator lamp flashing and the drum full of water. I’m not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain, but I think the program dial gets to the end. When this happens (as per the advise in the user manual) I drain the machine manually and check the pump for blockages. The first time I did this there was a blockage, but subsequent times the pump has not been blocked. The thing is though, after go through this procedure the washing machine then starts working again for several weeks until the next time the fault develops. Any ideas anyone?
Thanks,
Shaun.January 11, 2009 at 2:42 pm #273663Penguin45
ParticipantRe: Bosch WFF 2000 Intermittently Not Draining
It’ll be an old, tired pump by now. Best get yourself one of THESE.
Power off if you intend to do this yourself.
January 11, 2009 at 7:52 pm #273664Shaunf
Thanks for that. I’ll probably get someone to do it, but out of interest, how would I go about doing it myself?
January 11, 2009 at 8:28 pm #273665Penguin45
Taking the front off gives complete access. Three screws for the panel, two to free the door lock, then slip the spring band for the door seal and all is revealed.
Unplug first….
February 17, 2009 at 8:19 am #273666Shaunf
The pump is steadily getting worse, so I’m going to order a new one and get the job done over the weekend. A quick question though, for the 2 screws either side of the front door, presumably when I remove these, the door lock and hinge mechanisms wont fall apart and require fiddly re-alignment to get them back together again right?
Thanks.February 17, 2009 at 6:40 pm #273667Penguin45
Just release the two for the door lock. It’s very straightforward to put back once the panel goes back on.
February 17, 2009 at 7:31 pm #273668Shaunf
The complete part number on the washing machine door is a bit worn, but it looks like WFF2000GB/11. The pump you indicated is compatible with the WFF2000GB/12, but there’s no mention of the WFF2000GB/11. ❓
February 18, 2009 at 12:12 am #273669February 18, 2009 at 8:05 am #273670Shaunf
Thank you sir.
February 20, 2009 at 9:18 pm #273671Shaunf
After putting the door seal back, I notice there are a couple of holes in the bottom (I don’t think I made them). Are these drain holes? Also, while the washing machine is running, is it normal for them to drip a little water into the base of the washing machine?
February 22, 2009 at 1:27 am #273672Penguin45
They just allow any water lying in the door seal to drain down into the drum.
February 22, 2009 at 10:23 am #273673nomadPaul
ParticipantYou shouldn’t get any water dripping/leaking into the appliance base .
March 13, 2009 at 5:23 am #273674trishane
I have the same problem, I thought it was the program, so maybe thats not it after all …help!!!!!!!!!!!!!!.
I am now in Australia & with me is my beloved bosch wff2000.
please help 😥 . thanks.March 13, 2009 at 5:28 am #273675trishane
Shaunf wrote:My Bosch WFF 2000 intermittently ends up with the prewash indicator lamp flashing and the drum full of water. I’m not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain, but I think the program dial gets to the end. When this happens (as per the advise in the user manual) I drain the machine manually and check the pump for blockages. The first time I did this there was a blockage, but subsequent times the pump has not been blocked. The thing is though, after go through this procedure the washing machine then starts working again for several weeks until the next time the fault develops. Any ideas anyone?
Thanks,
Shaun.The same for me mate, it’s driving me nuts. what do I replace, pump or program. thanks trishane
March 13, 2009 at 9:03 pm #273676Penguin45
Pump is cheap and wears out. Timer/control isn’t and doesn’t……
What’s the rest of the model number?
