bosch wff 2000 – not taking in conditioner from drawer
Home Forums Public Support Forums Help And Support Washing Machine Help Forum bosch wff 2000 – not taking in conditioner from drawer
  • #28001
    jonno999
    hello, i’m new here, and hope you can help! my machine is 11 years old with no breakdowns, so I cant complain at all. But, for a long time, it seems that it only draws the conditioner from the ‘dispenser drawer’ occasiobnally. I note that the entire draw and its housing seems to regularly attract a build of black mildew/mould, for reasons i do not know! is this preventing some process, and how do i prevent such a build up? i live in a hard water area and tend to use concentrated conditioner. may thanks in advance. thanks in advance, Jonno
    #216487
    gegsy
    Re: bosch wff 2000 – not taking in conditioner from drawer
    Hi Jonno
    Take look here, should give you an insight to your problem 😉
    http://www.ukwhitegoods.co.uk/modules.p … page&pid=5
    jonno999
    many thanks – the soap drawer is in a sink of bleach, and i’m searching for an old toothbrush to clean the drawer ‘insides’ !
    #216489
    nomadPaul
    If you look up onto the roof of the detergent drawer area , you should see some holes in the central channel ( may be 2 or 4 ) These are probably blocked and a way to attempt to clear them is with an electrical cable tie. You can push one of these into the holes to try and clear the blockage
    #216490
    clivejameson
    The only way to clean the roof of the dispenser box sufficiently IMO is to strip out the box and unclip the top from it…you can then get the channels completely clear under a hot tap poking them if necessary with some cable, and get a good flush going from the nozzles to the back of the unit.
    Then don’t forget to do a maintenance wash periodically…
    http://www.ukwhitegoods.co.uk/modules.p … ge&pid=162
