Bosch WFF 2000 PreWash light flashing
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WFF 2000 PreWash light flashing
  • #12159
    AlisonR
    The prewash indicator is flashing four times. Does anyone know what that means? I’ve checked the pump is clear.
    #148129
    Goatboy
    Re: Bosch WFF 2000 PreWash light flashing
    A little more information is needed please.
    When does this happen; and what is the machine doing?
    Is the machine filling with water OK?
    Tell us as much as you can please.
    #148130
    AlisonR
    The machine fills with water as normal and it drains but does not spin so it only went part of the way through the programme and then stopped. Then the prewash light indicator started to flash. I noticed it making an odd noise on the previous day while the drum was going round during the wash.
    #148131
    Motor action not being detected by computer – usually brushes worn out. Check Repairs@ or Directories for a repairer in your area.
    Power off if you wish to investigate further.
    Ilan
    Re: Bosch WFF 2000
    Hi Guys,
    It seams you all know your staff.
    We just moved to a new house with Bosch WFF 2000 and we can’t find it’s manual.
    can somebody suggest a link so we can egt if of the web or in any other way.
    thanks,
    Ilan
    #148133
    Dave_Conway
    Re: Bosch WFF 2000
    Ilan wrote:can somebody suggest a link so we can egt if of the web or in any other way.
    Not downloadable I’m afraid Ilan.
    From the Bosch website:
    You can replace your washing machine or tumble dryer manual in the following ways:
    You can order a replacement instruction book by emailing mks-spares@bshg.com or completing the email form in the contact us section.
    You can order a replacement instruction manual from our customer service centre by ringing 08705 543210.
    The contact form refered to is here:
    http://www.bshappliancecare.com/Bosch/contactform.html
    Hope this helps 🙂
    #148134
    gegsy
    is it a Wff2000Gb /01/11/12 or14
    Cheers
    greg
