bosch wff 2001
  • #37627
    tvr1
    hi guys i have a problem with my wff 2001 washer, all is ok up to the rinse cycle and then it stops with the rinse/spin lights flashing i have cleaned the filter and pump and anything else i could find ,what i did notice is on the circuit board there was black duct and it seems to be carbon as there is also some on the drum pulley i have cleaned it all of but its still the same if at this piont i move the programmer round on to rinse it rinses and then spins ok any ideas thanks
    #255861
    CometBez
    Re: bosch wff 2001
    Hi tvr1,
    The black dust is brush residue from the motor, it is very common in all older appliances, and it gets everywhere 😀
    The failing to rinse/spin sounds like an external drainage fault, the appliance cannot drain the water away in the time it should, the appliance will stop rather than spin with water still to drain.
    If you are connected to a spigot under the sink, disconnect, blank off the spigot, put the hose into your sink, then get the appliance to drain, if it drains & continues happily to the finish you have a blockage somewhere within your pipework.
    If thats the case, best contact someone through this site who is local to you & who are all reputable, basically they wont rip you off 😉
    Cheers
    #255862
    tvr1
    Re: bosch wff 2001
    hi thanks for that i have it in pieces at the moment and have found scale in the plastic tank at the back to the side of the solonoids and i have cleaned this out there was quite a bit of muck in there im i right in thinking that if this slows the pumping out to any degree it will time out and give the problems i have
    #255863
    tvr1
    Re: bosch wff 2001
    hi i have just been reading some previous posts and read that if the solonoids have no reading with a meter they are faulty one of mine the yellow one on the cold feed in is giving no reading so its faulty the others are ok could this be the fault ,if so where can i get one and how much are they ? many thanks for such an excellent web site
    #255864
    Re: bosch wff 2001
    Water inlet valve is HERE.
