Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch WFF 2001: drum not turning – brushes OK
- This topic has 5 replies, 3 voices, and was last updated 18 years, 6 months ago by
40teabags.
October 7, 2007 at 5:10 pm #31163
40teabags
ParticipantOur 8-year-old Bosch WFF 2001 has just developed a problem. A couple of evenings ago it tripped its circuit breaker and now, although the wash programme still appears to run its course, the drum does not rotate. Whenever it’s meant to turn, I can hear the motor hum for a second or so and then stop.
The carbon brushes were replaced a couple of months ago, so this afternoon I took the motor out again (power off, of course!) to check one of them hadn’t stuck. They both appeared to be quite free and making good contact, and I cleaned the motor and all the connectors before refitting it. However, the motor still didn’t rotate after doing this.
So, with the belt off, I watched what the motor was actually doing, using the start of a spin programme. At the point the drum should have turned, the rotor rattled a few degrees in either direction and then whizzed round in one direction in a short burst, before freewheeling to a halt.
I’d be very grateful if anyone could suggest whether this is likely to be a problem with the motor itself, the controller or something else, perhaps, so I don’t embark on an expensive wild goose chase!
Thanks,
MikeOctober 7, 2007 at 5:45 pm #230037Penguin45
ParticipantRe: Bosch WFF 2001: drum not turning – brushes OK
It sounds like the armature is on it’s way out. New motor required.
October 7, 2007 at 7:10 pm #23003840teabags
ParticipantThanks for your quick response, Penguin.
It appears that motors are not available from the Bosch page in the shop. Where would I source a new one?
And what’s the damage likely to be…?
October 7, 2007 at 7:35 pm #230039Penguin45
P/no is 141344 – spares@ukwhitegoods.co.uk will get you one promptly.
Last time I looked it was £172.
October 7, 2007 at 8:45 pm #23004040teabags
Yikes!
In that case I think I’ll see if the rewinder round the corner can do anything with the old motor first.
Thanks again, Penguin.
October 7, 2007 at 9:08 pm #230041gegsy
Just to compound your dilemma even further, you may also have module damage due to the motor fault 😥
Just to give you the full picture incase you take the plunge with the motor 😉Greg
