Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch WFF 2001 Not starting wash cycle
- This topic has 16 replies, 6 voices, and was last updated 19 years, 7 months ago by
Octon13.
August 19, 2006 at 10:12 am #20081
Octon13
ParticipantMy trusty WFF 2001 has suddenly refused to start any wash cycle. I press the start button, the “Main Wash” light comes on then nothing. No drum movement, no sound of any water being taken in. No sound at all.
It is the same whichever wash cycle or temperature I select. I just removed a second load of washing from the machine and put in a third load so it had been running perfectly right up to the time of this problem.
All the lights toggle on/off when pressed. The door will release properly if I turn off the machine and wait a couple of minutes. But it will just refuse to start any wash cycle.
Can any one help? Desperate to finish off post holiday washing!
August 19, 2006 at 11:05 am #185740gegsy
ParticipantRe: Bosch WFF 2001 Not starting wash cycle
Will it spin?? If set to that instead of a wash cycle.
August 19, 2006 at 11:43 am #185741Octon13
Yes – I have just set it to the wool spin cycle and it has got going. Will let you know what happens after this finishes.
August 19, 2006 at 11:48 am #185742Octon13
Wool spin cycle completed OK
Tried a wash cycle but still not starting.
Judy
August 19, 2006 at 12:45 pm #185743superfix
Has the water been turned off to the m/c ?.
Or are the inlet hoses kinked ?.
August 19, 2006 at 2:49 pm #185744Octon13
Water is not turned off and no kinks in the water hoses. The machine had just finished one wash cycle succesfully, and when I reloaded it, it refused to start a new wash cycle.
If I look inside what should I be looking for?
Judy
August 19, 2006 at 3:33 pm #185745gegsy
With the appliance un-plugged :plug: you will need to check the resistence of the three fill valves individually and disconnected in turn, with a multimeter. (app 2-4kOhms) as boro mentioned.
If in any doubt, please use the repair link below off my sig.Greg
August 19, 2006 at 3:50 pm #185746gegsy
Hi Judy
Re your email regarding how to access the valves.
You will need to remove lid and the valves are situated at the rear of the appliance.
Un plug appliance before as always.Greg
August 19, 2006 at 3:54 pm #185747Octon13
Thanks Greg – I didn’t have anything better to do this evening anyway!
If we discover there is no resistance, can you give me some idea of what the solution might be and if it worth repairing?
I’ll contact you later when we have sussed the valve resistances.
Judy
August 19, 2006 at 3:57 pm #185748gegsy
Octon13 wrote:If we discover there is no resistance, can you give me some idea of what the solution might be and if it worth repairing?
Replacement of the valve/s that have no resistence. 8)
August 19, 2006 at 4:37 pm #185749Octon13
Sorry – of course! I will contact you again when we have investigated. Thanks for your help.
Judy
August 19, 2006 at 9:39 pm #185750Octon13
Hi Greg
We have established that it is the hot water inlet valve which has gone. Where would you recommend we get a new one and how much is it likely to be?
Judy
August 19, 2006 at 10:08 pm #185751Dave_Conway
It’s here in the shop@ Judy:
http://www.ukwhitegoods.co.uk/modules.p … cts_id=613 😀
August 19, 2006 at 10:50 pm #185752Octon13
Hi Dave
Thanks – the one we have has a red casing not white and the solenoid has the number 303 7041 AB0 on it. Will this be the same one? I am sure it must be as it is certainly the hot water inlet valve on the machine.
This forum is pretty impressive for help – thanks a lot everyone, particularly on a Saturday night!
Judy
August 19, 2006 at 11:59 pm #185753Penguin45
The valve fitted to your appliance has been superceded by the one illustrated in the shop@ facility. Manufacturers do do this in the search for reliability and/or cost saving.
Penguin45. -
