Bosch wff1201GB/01 motor toc blown
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch wff1201GB/01 motor toc blown
  • #17704
    Simon46
    Is the only repair for the worn out motor brushes also blown toc new motor? 🙁 . Does this mean that the armature is fried as well? No burnt or visible high segments.
    Regards
    Simon
    #175832
    Dave_Conway
    Re: Bosch wff1201GB/01 motor toc blown
    It looks like it Simon 🙁
    Nothing else showing apart from the brushes or the whole motor, part number 141344
    #175833
    Simon46
    If i take out a toc from a good motor whats the likelyhood of armature blowing it again? dont want to have unservicable stock appliance.
    Regards
    S.
    #175834
    Is it not possible to squeeze a TOC17 into these motors, it may not cure the fault but it would save spoiling a good motor.
    #175835
    iadom wrote:Is it not possible to squeeze a TOC17 into these motors
    I don’t think the Bosch motor has a TOC fitted as such? I believe it is a in-line fuse (current rather than temperature)????
    If the armature meggers to infinity it will be fine, usually it is just the brushes shorting to earth that blows the fuse (TOC). The chain reaction can also lift and blow a couple of tracks on the module board too. (which can be resoldered with link wire anyway 😉 ).
    The later series motors don’t have any fuse fitted and that is why when those motors ‘blow’, they take the Control Module with them!!! 😯
    Bosch’s standards are dropping with each new model that comes out 🙁
    #175836
    I’m with Jim on this one – been fiddling Toc17s into the brush plate for years.
    Simon46
    Thanks all will have a go at TOC17. How is it secured?
    S.
    #175838
    Tags are soldered to the brass – they will prise off, the actual TOC is held by two melted plastic blobs. I use a skinny tyrap to secure the new one with no problems.
    Hmmmmmm interesting reading, I wonder what LMTGOWIT uses? 🙄
    #175840
    Martin wrote:Hmmmmmm interesting reading, I wonder what LMTGOWIT uses? 🙄
    A strip of Baco foil perhaps. 🙂
