Bosch WFF1401 motor housing
  • #15142
    Enr WFF1401GB/01
    FD 7905 02899
    Motor brushes worn, appears customer has been turning the drum to kick start it a couple of times 😥
    Timer/Control unit has no obvious damage, motor overload has blown, comm cleaned up OK. Does the motor housing incorporate an new overload, is this a feasable repair, ( overload blown on Hotpoint almost always needs new armature ) and is the housing part number 096331 (six pin motor) ❓
    #162293
    Re: Bosch WFF1401 motor housing
    Just had a look on Bosch Quickfinder, is the motor brush housing not available as a separate part for this model?
    #162294
    ANDYVIVO
    No, it is a motor only. Motor end frames from Bosch always have a new thermal cut out.
    Motor 141344 is in stock at Masterpart
    Regards Andy
    #162295
    iadom wrote:Just had a look on Bosch Quickfinder, is the motor brush housing not available as a separate part for this model?
    What Quickfinder are you looking at Jim? Sure they are available seperately (154740)
    #162296
    ANDYVIVO
    154740 is all that is available for repair to these motors
    #162297
    Whoops! 😳
    I’ve re-read your post Jim and Andy is correct in that a complete motor the only answer in this case. The TOC blowing is not a good sign and its a 50/50 chance the armature is duff. 096331 possibly may work however if you have one to try first that is 😉
    #162298
    Thanks for replies, had checked out motor at Masterpart, need to break the bad news to customer. 🙂
    #162299
    Bye eck, £164.59 list price inc Vat. 😥
    However, I have convinced the customer that a new motor on this machine is a better use of £200+ than his intended course of action, which was to go and buy a new £200 washer. 🙂
