bosch wff1401gb/01
  • #53456
    cristalliera
    Hi all.
    Could anyone tell me please how to replace the above make thermostat? Where is it? Thank you for your time.
    #316077
    helo_75
    why?
    have you tested it? can ypu be sure its faulty, or even has a thermostat as such?
    #316078
    cristalliera
    helo_75 wrote:why?
    No m8 you are right i can not be sure! Can you direct me on the right track please? The washing machine works ok apart from the fact that it does not heat up the water anymore. Thanks.
    #316079
    helo_75
    does it go through its program?
    r u basing you assumption on felling the glass? or wash performance
    theres no other substitute for taking a multimeter and testing the element
    #316080
    cristalliera
    helo_75 wrote:does it go through its program?
    Thanks for answering back.
    The glass has always been hot to touch when meant to be.
    Where is the element on these machine? Is it easily accessible? Ta.
    #316081
    Re: bosch wff1401gb/01
    You would be far better served if you actually explained the nature of the problem which you are struggling with.
    The machine does not have thermostat. It uses ntc or “thermistor” electronic temperature control. A thermistor is a variable resistance device – the hotter it gets, the lower the resistance. The pcb reads the resistance to decide the temperature. The sensor is attached to the lower front underside of the tub. I have never changed one, although I have occasionally had to repair the wiring to them. The front panel can be removed for access.
    Heating element is at the lower tub rear – back panel off for access.
    Power off at all times, please.
    Penguin45,
    Moderator.
    #316082
    cristalliera
    Penguin45 wrote:You would be far better served if you actually explained the nature of the problem which you are struggling with.
    Thank you Penguin45
    Penguin45,
    Moderator.
