Bosch WFF2000 Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch WFF2000 This topic has 6 replies, 6 voices, and was last updated 16 years, 1 month ago by Penguin45. Viewing 7 posts - 1 through 7 (of 7 total) Author Posts February 9, 2010 at 9:13 am #52351 Penguin45Participant Motor runs in wash, not at final spin. After several minutes, timer advances to end with pre-wash led blinking three times. Pressure system appears to work. Any ideas? Chris. February 9, 2010 at 11:36 am #311440 electrofixModerator Re: Bosch WFF2000 does motor reverse in wash if not check pcb relays Dave February 9, 2010 at 1:54 pm #311441 superfixParticipant Re: Bosch WFF2000 3 flashes is pump fault apparently 😕 February 9, 2010 at 2:26 pm #311442 timdowningParticipant Re: Bosch WFF2000 Don’t want to state the obvious because I’m sure you did …. did you insulation test the heater? February 9, 2010 at 7:05 pm #311443 PINKYParticipant Re: Bosch WFF2000 Blocked pressure chamber was a favourite on these and while your cleaning that its wise to check the heater, Clear the anti syphon box and check valve coils. Usually covers all bases assuming it passes the Mega test 😉 February 12, 2010 at 9:23 am #311444 MartinParticipant Re: Bosch WFF2000 I’m with Tim, I bet it’s the heater. February 19, 2010 at 8:12 pm #311445 Penguin45Participant Re: Bosch WFF2000 Sadly, it turned out to be the programmer in the end. Thanks to all for the input. Chris. Author Posts Viewing 7 posts - 1 through 7 (of 7 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
