Bosch WFF2000 Fault Code 4
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WFF2000 Fault Code 4
  • #31943
    WarwickGrigg
    Cycle finishes with wet washing and error code. So I select the Easycare spin program. The drain pump runs then the program clicks slowly to the end without spinning. The pre wash light flashes error code 4 (four flashes – wait – four flashes etc). The full E-NR of my Bosch WFF 2000 Washer is WFF2000GB/12 FD7703 05257. Any ideas what this means? Brushes?
    Earlier today I de-sludged the clear plastic box that sits just in front of the drain pipe. I’m thinking this is just a co-incidence because it completed a full wash and spin OK straight afterwards.
    Many thanks. Warwick.
    #233028
    gegsy
    Re: Bosch WFF2000 Fault Code 4
    I would start by checking the motor brushes for wear 😉
    Un-plug appliance if you are to have a go :plug:
    Machine was made in March ’97, so it’s more or less got to be due a set of brushes by now.
    These are the ones that fit your machine:
    http://shop.ukwhitegoods.co.uk/product_ … 8b24727f8c
    This article:
    http://www.ukwhitegoods.co.uk/modules.p … ge&pid=156
    offers some good insight into what is involved.
    Power off, if investigating.
    Good Evening, Greg.
    :p45:
    #233031
    gegsy
    Hello Mr P :waving:
