Bosch wff2000 no spin
  • #46326
    cornwell40
    One of those customers who whatever is wrong with the old machine has a reletive with a washer in the garage. This is one of them :rolls: .
    Called out after they swapped it drain pump rattling like mad. Changed pump, tests ok.
    Now complains of no spin. Hols tomorrow so I had a quick look this evening, when put on spin advances to the end of the spin programme immediately, pump goes for about ten seconds machine continues to tumbl for 30 seconds then switches off.
    When I moved the programme selector to the x position, the indicator knob just rotates forever. No prewash light up. 😕
    Any ideas, going back after hols.
    TC
    #288945
    Re: Bosch wff2000 no spin
    Timer/pcb unit. They’ll never pay for that. Forget it, enjoy holiday.
    cornwell40 wrote:when put on spin advances to the end of the spin programme immediately, pump goes for about ten seconds machine continues to tumbl for 30 seconds then switches off.
    Crudded up air chamber and earth leak on heater will give these symptoms. 😉
    #288947
    cornwell40
    Cheers guys
    And :waving: hi all from sunny Scarborough.
    TC
    #288948
    rolf
    Ahhhhhhhhhhhh scarbrough have fond memories of that place for a couple of reasons one I got engaged to the wife up there and two it has the best scary house amusement in the world.Enjoy your holiday .If you see someone running out of a shop front screaming.Pay the couple of quid to go in its worth every penny. 😆
