BOSCH WFF2000 PRE WASH LIGHT ON
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries BOSCH WFF2000 PRE WASH LIGHT ON
  • #17760
    mbdas
    HI 🙂
    CUSTOMER SAYS THE MACHINE GOES THROUGH THE PROGRAMME ON THEN STOPS FULL OF WATER NEAR THE END OF THE PROG WITH THE PRE WASH LIGHT ON ❓ IVE TRIED DOWN LOADING THE MANUAL BUT MY GERMAN IS **** ANY IDEAS ❓
    MARK
    #176246
    Simon46
    Re: BOSCH WFF2000 PRE WASH LIGHT ON
    The usual pump/ coin/ blockage Mark 😀 .
    Regards
    Simon
    #176247
    mbdas
    Thanks Simon 🙂
    at least I will have somewere to start 😀
    mark
    #176248
    mbdas
    Hi 🙂
    Ive been to this and no blockage pump ok 🙁 the pre wash light flashers 3 times does anyone know what that is ❓
    thanks
    #176249
    gegsy
    Does it put this fault up if you ro a rinse and spin or a full wash?
    Fault – 3 flashes on pre wash lamp is drain taking longer than 6 mins, for whatever reason, weak/damaged pump or blockage etc. Pump can during wash become intermittent due to wear, the heat of the wash compounds this.
    mbdas
    Hi 🙂
    Ive no feed to pump and no motor action on the very last rinse always goes faulty in the same place between last rinse and rinse hold just sits there for about 4 mins and then quickly advances to the end and the pre wash light flashers.
    mark 🙂
    #176251
    gegsy
    Sounds like a faulty power module.
    Do you have the full model number.
    mbdas
    thanks greg 🙂
    ive just quoted customer for a timer/module, he going to currys 🙁
    Mark
    #176253
    gegsy
    Did you give him the ISE info and what value it is? 😉
