Bosch WFF2000 pump problem
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WFF2000 pump problem
  • #54938
    PhilA
    My machine (Bosch WFF2000GB/01, FD 7507 00306) failed to pump out a few months ago. I checked the filter and pipes (small amount of fluff removed, made no difference) and eventually gave the pump impeller a spin with my finger (with the power off!) which got it going again. I assumed some sort of ‘sticktion’. It’s run without problem since then but is now showing the same symptoms again.
    I’m guessing the pump is probably worn out, so plan on replacing the pump as it’s the original and the machine is about 15 years old now. Does that seem a sensible course of action? (The rest of the machine works fine).
    Your site lists a pump for WFF2000GB/12 (part BS51116). Please can you let me know if that will fit my machine as well? I’m not sur ehow much variance there is in the model number after the “/”. Alternatively, can you let me know the right part number please?
    Many thanks,
    Phil
    #321439
    spanishwhite
    Re: Bosch WFF2000 pump problem
    If you are certain that it is the pump then yes it is worth doing.Have just removed a bra wire from a 26yr old bosch,not a mark on it and in pristine condition inside.You can always ask the whitegoods shop and they will confirm if the pump will fit your machine.
    #321440
    THIS should be the part you need, well worth fixing. 🙂
    #321441
    PhilA
    Many thanks. Part now ordered.
    Phil
