Bosch WFF2000GB/01 How to replace Drum Paddle Lifter
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WFF2000GB/01 How to replace Drum Paddle Lifter
  • #83902
    fjs0
    First post. Machine is 21 years old. One paddle lifter is beginning to fragment in one fenestrated area. I have obtained a replacement lifter, but cannot discern how to release the drum tab. There are no holes for screwdrivers, and I cannot insert any thin metal object between the drum and the paddle lifter. This may have been asked many times, but cannot find instructions specific to this model.
    #424151
    Re: Bosch WFF2000GB/01 How to replace Drum Paddle Lifter
    The drum needs to be removed to fit those lifters. There is no other way. 🙁
    #424152
    fjs0
    I take it the procedure is to
    remove front
    remove weight
    remove drum and undo marginal wire clips at front of drum assembly to remove inner drum and reveal whatever fasteners are used.
    No doubt there is a seal on the outer drum opening which will need to be replaced, if still manufactured.
    Do you recall the nature of the fittings holding the lifters in place?
    #424153
    It is held in place by the drum spigot fixing bolt and triangular washer (see drawing)
    #424154
    fjs0
    Thank you. Very helpful diagram.
