Bosch WFF2000GB/14 Starts spinning then stops, repeatedly
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WFF2000GB/14 Starts spinning then stops, repeatedly
  • #90624
    tom_w
    My Bosch is no longer spinning properly, it starts to spin for a second and then just spins down. It does this repeatedly throughout the spin part of the cycle. At the end of the cycle it’s flashing four times on the pre-wash light.
    I’ve changed the brushes which hasn’t helped and as far as I can see they seem to be touching the armature correctly. Does anybody know what else might be causing this behaviour?
    #445415
    Re: Bosch WFF2000GB/14 Starts spinning then stops, repeatedl
    Were the old brushes worn out and blackened?
    #445416
    tom_w
    They don’t look that bad to me, but I have nothing to judge them against:
    #445417
    They look OK. So, next question, if you were to put it now on a wash cycle, would would it fill and tumble OK?
    #445418
    tom_w
    Thanks Martin. I started it off on a normal wash and it did the same thing through the initial tumbling bit, spinning up briefly then stopping again, albeit more quickly (maybe due to the water resistance?). The water level was about an inch deep in the drum. It then did the same thing when it hits the first rinse spin.
    I’m running it empty at the moment, I’m assuming it’s not realising that and stopping.
    #445419
    The good news:
    The motor connecting plug wires may have been damaged? Carefully check the wires into that connecting block.
    The real bad news:
    The ‘tachometer generator’ magnet on the motor’s armature shaft has likely cracked and is broken. You’ll need to remove and dismantle the motor and inspect that magnet. If that is the case then it’s the end of the road for your machine as a new motor is the only resolve.
    #445420
    tom_w
    Real bad news it is:
    Such a shame, it looks pretty much brand new other than that and it looks so well engineered, much better quality than the Hoover one I replaced a belt on a while ago.
    Any recommendations for the replacement?
    Many thanks for all the help, it’s good to know I did what I could anyway!
