Bosch wff2001 sticks before rinse cycle, then….buzzing
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch wff2001 sticks before rinse cycle, then….buzzing
  • #53724
    Got a bosch wff2001 – 11 years old great! Suddenly the rinse and spin lights flash simultaneously. Handbook says this is a blocked drainage issue. I have stripped the drainage and ckecked the pump – all works fine. Now narrowed the fault to it not being able to automatically sitch into the rinse cycle. The machine locks up and buzzes for about 5 mins before it stops with its flashing leds. Its now clear that it wont rinse automatically, but if i switch off and manually turn the programmer to rinse it will rinse and spin.
    So whats the fauly and cure?
    #316965
    odom
    Re: Bosch wff2001 sticks before rinse cycle, then….buzzing
    Could be any one of a number of things – buzzing normally faulty solenoid for cold water valve, machine would use hot water during wash then time out after 5 mins of waiting for cold water to come in, although if it manually rinses fine it could be the module as well.
    What temperature do you wash on? Have you tried a 30C/cold wash and seeing if it starts up okay?
