Re: Bosch WFF2001 struggles to turn
Can be motor, can be electronics. If the brushes are below 10mm, they’re finished and need replacing – the spring is extended and may not exert sufficient pressure to ensure a clean contact on the armature. If the motor struggles to wash but will spin (not at full speed), the motor will definitely be at fault. If there are any clicking noises as the motor turns, it’s blown, similarly if it goes “Ong” before turning.
Expert or not, power off before sticking fingers in.
HTH,
