Bosch WFF2001GB/01 – Drum not spinning
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WFF2001GB/01 – Drum not spinning
  • #19162
    David_M
    Hi, we have a 6+ yr old Bosch WFF 2001 washing machine in which – as of yesterday – the drum won’t spin when we put it on it’s usual colour wash cycle.
    The water fills up on start, and I can hear the switches clicking as usual, but the drum doesn’t spin. I’ve checked the fan belt and it’s good and intact, so I assume the problem lies with the motor or something?
    Is there anything else I can check to see what might actually be causing this fault?
    Thanks for any help.
    Cheers,
    David
    #181943
    gegsy
    Re: Bosch WFF2001/GB – Drum not spinning
    If you remove motor and check brushes, Im sure you will find them worn down (App 1.5″).
    Use the link below to find a pair, original p/no is 154740.
    Un plug appliance before attempting repair :plug:
    Regards
    Dave_Conway
    Re: Bosch WFF2001GB/01 – Drum not spinning
    gegsy wrote:Posted: Sat Jul 15, 2006 3:21 am
    Do you never sleep man ? 😯
    #181945
    gegsy
    zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz 😆
    #181946
    David_M
    gegsy wrote:If you remove motor and check brushes, Im sure you will find them worn down (App 1.5″).
    I’ve got the back off the washing machine. Any suggestions where I can find instructions on how to remove the motor? Don’t want to damage it or anything trying to get it off. Sorry if that’s a silly question or anything.
    #181947
    gegsy
    Without sounding rude, if you are asking that ; I would suggest using the link below for an engineer.
    Regards
    David_M
    No problem. Actually, was just going to edit my post to say I found some instructions online at http://www.howtomendit.com/answers.php?id=1800. Will see how well it goes, but if I get stuck or don’t think I can do it, I’ll take your advice.
    Thanks,
    David
    #181949
    David_M
    Update: Got the motor out OK and checked the brushes – both worn down to approx. 3/8ths of an inch (or 1cm). Have ordered replacement brushes from Shop@. Many thanks for your help.
    Cheers,
    David
    #181950
    gegsy
    Glad you sorted David, just gets a bit worrying when you get asked a basic task to change brushes thats all. Just trying to keep you and whoever else reads this post safe.
