Bosch WFG2020/GB01
  • #23879
    rocker
    can anyone give me some advice, customer tells me it washes in cold water, not heating but completes cycle, I thought a bosch wouldnt advance if stat dosent sence heater. I could be wrong…does anyone know for sure before I call to look.
    Cheers John
    #199692
    Re: Bosch WFG2020/GB01
    Most machines these days tend to complete cycles after a given time. Gone are the days of waiting for a stat to close/open.
    #199693
    gegsy
    Depending on what wash she uses, she may not feel heat as the water is lower than the glass until the rinse cycle.
    If there was a heating problem, a fault lamp sequence would become apparent, namely “Ready” and “Active ” lamps would be flashing and the machine would continue the cycle as normal (in cold water) till the end.
    HTH
    rocker
    Thanks to Eastlmark & Greg for your help & advice
    John
    #199695
    You are welcome John,
    Best way to tell if machines are heating is to use a clamp meter on either the L or N wire. I have often used this method to prove to customers that their machine is heating after they have sworn it isnt as the glass didnt feel hot.
