Wonder if any of you can throw some light on this problem, I had a call to this appliance for sticking in the cycle. Checked the heater element and found it blown along with a blocked pressure system.
Fitted new element and cleared pressure system and run of 40c wash, the machine fills very slowly and then stops filling and goes into wash action.
The water level is so low that it is below the drum, on rinses the machine starts to fill, then pumps out, then fills, then pumps out, then fills, then starts the rinse action, the water level has filled more but still looks too low to me as it is below the door seal about 2 inches.
Is this likely to be a PCB board problem or faulty pressure switch, I do not have another P/switch to substitue it is the oval brown type.
Any help appreciated
