Bosch wfk 2801 problem
  • #33854
    kinglung
    i have problem with above machine its starting its wash programme the display is counting down to 1 minute as noramal but the machine is still on wash part of cycle which it keeps up all day if you let it
    #240332
    gegsy
    Re: Bosch wfk 2801 problem
    Mmm, possibly a heating problem 😕 , worth giving the heater the once over.
    Un-plug appliance first before investigating :plug:
    #240333
    kinglung wrote:checked heater element working ok. just stuck on main wash time left counts down to 1 minute and stops there but washer keeps washing and washing all day if you let it
    Please keep it in one thread – gets very confusing otherwise………
    Penguin45,
    Moderator.
    #240334
    kinglung wrote:Just an update on my stuck on mainwash problem this problem does no occur on 15 degree washes it goes through its cycle normally on warm washes the water is getting warm i can feel heat through washer door any advice please
    And again……..
    #240335
    Right, so no-one’s got a magic fix for you, you’re going to have to apply a bit of logic.
    If set to spin or rinse programmes, does the machine complete the programmes?
    If set to a 15c wash, you will not feel heat on the glass, or see condensation forming – unless the machine is overheating? If the temperature control circuit is not working, the programme will not advance, just get hotter and hotter.
    The wash programme will utilise hot and cold fill to get close to the required wash temperature – 15c is easy – 40c is not.
    I would suspect that your heater has failed. You need a test meter and the ability to use it properly to find out for sure. If you can’t do it, get pro help – use the link below for someone in your area.
    Good quality machine, worth persevering with.
    Power off if you are going to sort this for yourself.
    And stop starting new threads………!
    gegsy
    More likely heater as we have said, only a test meter will aid you.
    With the power off it should read approx 20-30 ohms.
    If that checks out it could be a numerous things from sensor to module 😕
    If in any doubt please feel free to use the repairs@ link to save yourself from making an expensive mistake.
    kinglung
    cheers for your help . i tested the heat sensor that giving an ok reading tested heater element which gives no reading at all so i think ive found my culprit thanks for you help much appreciated
    #240338
    gegsy
    gegsy wrote:Mmm, possibly a heating problem 😕 , worth giving the heater the once over.
    Why you no rissen 😀
    kinglung
    new water heater fitted and running perfect yet again thanks for your help
